Hi, I need help and/or advice with creating a river mileage shapefile using the data I have:
- river network (linear shapefile - vector data)
- ordinate data (altitude data in point shapefile) spread across the river network (so I know which way the river flows).
There are two problems with the data I have:
1. the river network consists of smaller sections creating rivers - it means that one river is divided into smaller sections but in the attribute table of each section there is an attribute with the name of the river so it can be easily identified how many sections each river has
2. the river network is 300 000 sq. km so it makes the analysis very laborious.
I decided on the process to do and I need your advice if it is ok and how to do it step-by-step in ArcGIS 10.2.
First, I am planning to join each section of the river into one line so every river with different name attribute would be separated. Q: how to do it using the fact that the sections have the same name attribute? Any python script?
Secondly, I need to determine spring and mouth for every river based on the ordinate data (point shapefile) - with tool would be the best for it, how to make it?
Lastly, I need to create the point shapefile with the mileage points across the river network at 100 interval. The shapefile will be huge. How to do it? Is it possible to make steps 2&3 as one step?
I would be grateful for any advice on that.
Kind regards,
Michal
