Hello ,
I am getting a problem in plotting the graphics and zoom into the feature on the map. Here below is my code. Please help. The data is getting populated into the grid and after that it is not zooming into the map.
define([
"dojo/_base/declare",
"dijit/_WidgetBase",
"dijit/_TemplatedMixin",
'dijit/_WidgetsInTemplateMixin',
'dojo/_base/lang',
"esri/tasks/query",
"dojo/text!/Widgets/SearchButton/SearchButton.html",
"xstyle/css!/Widgets/SearchButton/css/StyleSheet.css",
"esri/Color",
"esri/tasks/locator",
"esri/InfoTemplate",
"esri/symbols/Font",
"esri/symbols/TextSymbol",
"dojo/_base/array",
"dojo/number",
"dojo/parser",
"esri/tasks/FindTask",
"esri/tasks/FindParameters",
"dojo/_base/connect",
"dojox/grid/DataGrid",
"dojo/data/ItemFileReadStore",
"esri/graphic",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleMarkerSymbol",
"dojo/on",
"dijit/form/Button",
"esri/geometry/Point",
'require',
"dojox/widget/Standby",
"dojo/_base/window",
"dojo/window",
"dojo/dom",
"dojo/dom-attr",
"dijit/registry",
"dijit/form/NumberTextBox",
"dijit/Dialog",
"esri/tasks/geometry",
"dojo/domReady!"
], function (declare, _WidgetBase, _TemplatedMixin, _WidgetsInTemplateMixin, lang, query, template, widgetCss,
Color, locator, InfoTemplate, Font, TextSymbol, array, number, parser, FindTask, FindParameters, connect, DataGrid, ItemFileReadStore,
Graphic, SimpleLineSymbol, SimpleFillSymbol, SimpleMarkerSymbol, on, Button, Point, require,
Standby, win, window, dom, domAttr, registry, NumberTextBox, Dialog,
Geometry) {
var imageUrl = require.toUrl("./images");
var searchDialogbox;
var center, zoom;
var grid, store;
return declare([_WidgetBase, _TemplatedMixin, _WidgetsInTemplateMixin], {
// widgetsInTemplate: true,
templateString: template,
map: null,
Map: null,
imageUrl: imageUrl,
findParams: null,
searchDialogbox: null,
findtask: null,
searchText: null,
spatialReference: null,
featureUrl:null,
map: this.map,
//doFind:null,
postCreate: function () {
findtask1: function () {
this.findtask = new FindTask("http://");
this.findParams = new FindParameters();
this.findParams.returnGeometry = true;
this.findParams.layerIds = [0];
this.findParams.searchFields = ["OBJECTID","FEEDER_NAME"];
this.findParams.outSpatialReference = this.map.spatialReference;
console.log("find sr: ", this.findParams.outSpatialReference);
doFind: function () {
//Set the search text to the value in the box
this.findParams.searchText = this.ownerName.value;
this.findtask.execute(this.findParams, lang.hitch(this, this.showResults));
showResults: function (results) {
console.log(results);
this.map.graphics.clear();
var symbol = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
new Color([98, 194, 204, 0.5])
//create array of attributes
var items = array.map(results, function (result) {
var graphic = result.feature;
console.log(graphic);
graphic.setSymbol(symbol);
this.map.graphics.add(graphic);
return result.feature.attributes;
console.log("alertqb");
var data = {
identifier: "OBJECTID", //This field needs to have unique values
label: "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
items: items
//Create data store and bind to grid.
store = new ItemFileReadStore({
data: data
var grid = registry.byId("grid");
grid.setStore(store);
grid.on("rowclick", lang.hitch(this, this.onRowClickHandler));
console.log("rowclick");
//Zoom back to the initial map extent
this.map.centerAndZoom(center, zoom);
onRowClickHandler: function (evt) {
console.log("1");
var clicked = evt.grid.getItem(evt.rowIndex).OBJECTID;
console.log('clicked');
var selected = array.filter(this.map.graphics.graphics, function (graphic) {
return ((graphic.attributes) && graphic.attributes.OBJECTID === clicked);
console.log('clicked20');
if (selected.length) {
this.map.setExtent(selected[0].geometry.getExtent(), true);
console.log('clicked25');
