I've recently noticed that my print widget is not working in one of my maps. However, it is working in two other maps. All three maps call to the same service and the same code blocks are used in all maps.
The biggest difference I have been able to locate between the maps is that the map where the print widget is not working is in 3.17, where the other two are in 3.14. I'd like to update my code in the one map so the print widget will work as it should. I've looked at the API reference for potential changes, but that hasn't proven to be fruitful.
When this map was first released, the print widget was working, so there is the chance the recent addition of tooltips is what has thrown this off. Any ideas?
Function and require statement:
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"dojo/dom-construct"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/keys"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/sniff"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/SnappingManager"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/config"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/graphic"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/lang"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/webMercatorUtils"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/BasemapGallery"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/HomeButton"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/Search"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/Popup"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/PopupTemplate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/Scalebar"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/Print"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/dijit/Measurement"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/InfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/ArcGISDynamicMapServiceLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/GeometryService"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/PrintTemplate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/PictureMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/toolbars/draw"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/urlUtils"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/request"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"agsjs/dijit/TOC"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/_base/array"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/aspect"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/dom-style"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/ready"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/on"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/TooltipDialog"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/popup"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/TitlePane"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/form/Button"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>domConstruct<SPAN class="punctuation token">,</SPAN> Map<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">,</SPAN> keys<SPAN class="punctuation token">,</SPAN> has<SPAN class="punctuation token">,</SPAN> SnappingManager<SPAN class="punctuation token">,</SPAN> SimpleRenderer<SPAN class="punctuation token">,</SPAN> esriConfig<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> esriLang<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN> webMercatorUtils<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN> BasemapGallery<SPAN class="punctuation token">,</SPAN> HomeButton<SPAN class="punctuation token">,</SPAN> Search<SPAN class="punctuation token">,</SPAN> Popup<SPAN class="punctuation token">,</SPAN> PopupTemplate<SPAN class="punctuation token">,</SPAN> Scalebar<SPAN class="punctuation token">,</SPAN> Print<SPAN class="punctuation token">,</SPAN> Measurement<SPAN class="punctuation token">,</SPAN> InfoTemplate<SPAN class="punctuation token">,</SPAN> ArcGISDynamicMapServiceLayer<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN> GeometryService<SPAN class="punctuation token">,</SPAN> PrintTemplate<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol<SPAN class="punctuation token">,</SPAN> SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN> PictureMarkerSymbol<SPAN class="punctuation token">,</SPAN> Draw<SPAN class="punctuation token">,</SPAN> urlUtils<SPAN class="punctuation token">,</SPAN> esriRequest<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> TOC<SPAN class="punctuation token">,</SPAN> array<SPAN class="punctuation token">,</SPAN> aspect<SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">,</SPAN> domStyle<SPAN class="punctuation token">,</SPAN> ready<SPAN class="punctuation token">,</SPAN> on<SPAN class="punctuation token">,</SPAN> TooltipDialog<SPAN class="punctuation token">,</SPAN> dijitPopup
<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Layouts:
<SPAN class="keyword token">var</SPAN> myLayouts <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Print_Landscape"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"label"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Landscape"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"format"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"pdf"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"options"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"legendLayers"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// empty array means no legend</SPAN>
<SPAN class="string token">"scalebarUnit"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Miles"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"titleText"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"State Parks"</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Print_Portrait"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"label"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Portrait"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"scaleBarUnit"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Miles"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">/*
* Step: create the print templates
*/</SPAN>
<SPAN class="keyword token">var</SPAN> myTemplates <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
dojo<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>myLayouts<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>lo<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> t <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PrintTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
t<SPAN class="punctuation token">.</SPAN>layout <SPAN class="operator token">=</SPAN> lo<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">;</SPAN>
t<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">=</SPAN> lo<SPAN class="punctuation token">.</SPAN>label<SPAN class="punctuation token">;</SPAN>
t<SPAN class="punctuation token">.</SPAN>format <SPAN class="operator token">=</SPAN> lo<SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">;</SPAN>
t<SPAN class="punctuation token">.</SPAN>layoutOptions <SPAN class="operator token">=</SPAN> lo<SPAN class="punctuation token">.</SPAN>options
myTemplates<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>t<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Print Widget:
<SPAN class="keyword token">var</SPAN> printMap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> mapMain<SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">async</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fconservationgis.alabama.gov%2Fadcnrweb%2Frest%2Fservices%2FDCNRExportWebMap%2FGPServer%2FExport%2520Web%2520Map" target="_blank">https://conservationgis.alabama.gov/adcnrweb/rest/services/DCNRExportWebMap/GPServer/Export%20Web%20Map</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN>
templates<SPAN class="punctuation token">:</SPAN> myTemplates
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"PrintButton"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
printMap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Tooltips:
tooltips<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>tooltipFill<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
tooltips<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'mouse-over'</SPAN><SPAN class="punctuation token">,</SPAN> mouseOverGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
tooltips<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'mouse-out'</SPAN><SPAN class="punctuation token">,</SPAN> mouseOutGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//mouse over graphic</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">mouseOverGraphic</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//disableTimer();</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clearFeatures</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setTitle</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">" "</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>NAME<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>screenPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">mouseOutGraphic</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">timedClose</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">timedClose</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">clearTimeout</SPAN><SPAN class="punctuation token">(</SPAN>timer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
timer <SPAN class="operator token">=</SPAN> <SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hide</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2000</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">disableTimer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//I am using mapinfowindow so I attach mouseover and mouseout to the infowindow</SPAN>
infoWinMouseOver <SPAN class="operator token">=</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>mapMain<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'mouseover'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">disableTimer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
infoWinMouseOut <SPAN class="operator token">=</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>mapMain<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'mouseout'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
