I get this error in the console when I try to "Launch" my app. I found that an extra condition in the ConfigManager.js, where the error occurs, resolves this.
Line 472:
_processWebTier: function(appConfig){
var def = new Deferred();
var portalUrl = appConfig.portalUrl;
if(appConfig.isWebTier){
//Although it is recommended to enable ssl for IWA/PKI portal by Esri,
//there is no force on the client. They still can use http for IWA/PKI.
//It is not correnct to assume web-tier authorization only works with https.
tokenUtils.isWebTierPortal(portalUrl).then(lang.hitch(this, function(isWebTier) {
var credential = tokenUtils.getPortalCredential(portalUrl);
if(credential){ // condition added by alterwiel
if(credential.ssl){
//if credential.ssl, it means that the protal is allSSL enabled
if(window.location.protocol === 'http:' && !tokenUtils.isInConfigOrPreviewWindow()){
window.location.protocol = 'https:';
return;
def.resolve(isWebTier);
}), lang.hitch(this, function(err) {
def.reject(err);
}else{
def.resolve(false);
return def;
