I have published a map for field workers to use, some of the fields they need to capture information for are being turned off.
I have checked the master MXD, which I used to publish the data to the Server for ArcGIS and the fields are present. When I load the data off the Server, two fields are switched off or "hidden". Turning them back on is fine for the map, but if I save and close the map the fields revert to being hidden.
My field workers cannot capture.
Any ideas as to why this is happening?
On a side note, I created the same map for January data collection and it worked beautifully. Re-publishing the same data for my February maps have resulted in this error.
Thank you!
