I'm a programming-beginner and I am currently writing my first Python-Script. That's why the question is more a general (or perhaps a semantic) one. I want to write a specific ID to the attribute table of an existing shapefile. This ID is amongst others composed of the coordinates (centroid) of the shape. So I tried the following:import arcpy arcpy.env.workspace = "**************" outline = "***********testoutline7.shp" fields = ['SHAPE@XY'] with arcpy.da.SearchCursor(outline, fields) as cursor: for row in cursor: coordX = row[0][0] if coordX < 0: coordX = coordX + 360 coordY = row[0][1] print "X: {}, Y: {}".format(coordX,coordY) #----transformation of the centroid-coordinates---# Xrnd = round(coordX, 3) longitude = str(Xrnd) glimsLongitude = longitude.split('.') Yrnd = round(coordY, 3) latitude = str(Yrnd) glimsLatitude = latitude.split('.') #-----------------------------------------# with arcpy.da.UpdateCursor(outline, "GLIMS_ID") as crsr: for glims in crsr: glims[0] = "G" + glimsLongitude[0] + glimsLongitude[1] + "E" + glimsLatitude[0] + glimsLatitude[1] + "N" crsr.updateRow(glims)The problem is, that after processing there is the same ID in every polygon of the shapefile. I'm using only a test-shapefile to try it and it consists of 3 polygons. They all get the same ID in their attribut-field "GLIMS_ID". But the print-statement above on the other hand returns all the different coordinates of the different polygons. What's the mistake?I know, the code requires a lot of revision and it is not yet beautiful. I would therefore be open-minded for every other suggestion for improvement. I also tried to vary the "position" of the last 4 lines, without success.Thank you for your help!
