JS API version 4.12
I'm generating my own custom popup content, specific to each sublayer in my map image layer. I don't want to hard code dozens of fields in 40+ layers like this:
content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"<tr><td>Utility ID: </td><td>{UtilityID}</td></tr>"</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>It's going to be more of a custom template with some functions applied to common fields throughout many layers.
When creating a function for the sublayer.popupTemplate's content, the only thing I have available in the graphic's attributes are field names. Can I not easily get the aliases for these features? I don't see a more direct way to do this aside from a traversing through the metadata of the entire map image layer using an esriRequest...get layer field name/alias pairs into an array. Can I avoid the overhead of an esriRequest?
<SPAN class="comment token">// Create identify task for the specified map service</SPAN>
<SPAN class="keyword token">var</SPAN> identifyTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">IdentifyTask</SPAN><SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">.</SPAN>mapImgLyrUtil<SPAN class="punctuation token">.</SPAN>url<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Set the parameters for the Identify</SPAN>
<SPAN class="keyword token">var</SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">IdentifyParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>tolerance <SPAN class="operator token">=</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>layerOption <SPAN class="operator token">=</SPAN> <SPAN class="string token">"visible"</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>width <SPAN class="operator token">=</SPAN> app<SPAN class="punctuation token">.</SPAN>mapView<SPAN class="punctuation token">.</SPAN>width<SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>height <SPAN class="operator token">=</SPAN> app<SPAN class="punctuation token">.</SPAN>mapView<SPAN class="punctuation token">.</SPAN>height<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> arrExcludeFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHAPE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHAPE.STLENGTH()"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">executeIdentifyTask</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
params<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>mapExtent <SPAN class="operator token">=</SPAN> app<SPAN class="punctuation token">.</SPAN>mapView<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">;</SPAN>
identifyTask
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN>
app<SPAN class="punctuation token">.</SPAN>mapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> executeIdentifyTask<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>mapView<SPAN class="punctuation token">.</SPAN>popup <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
dockEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
collapseEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
overwriteActions<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
defaultPopupTemplateEnabled<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
dockOptions<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom-right"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">createContent</SPAN><SPAN class="punctuation token">(</SPAN>content<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> graphic <SPAN class="operator token">=</SPAN> content<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//graphic's attributes are FIELDNAME: {value}</SPAN>
<SPAN class="keyword token">var</SPAN> displayContent <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> key <SPAN class="keyword token">in</SPAN> graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//key is the field name</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>arrExcludeFields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>key<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toUpperCase</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> attrVal <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>key<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
attrVal <SPAN class="operator token">=</SPAN> graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>key<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
displayContent <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> key <SPAN class="operator token">+</SPAN> <SPAN class="string token">": "</SPAN> <SPAN class="operator token">+</SPAN> attrVal <SPAN class="operator token">+</SPAN> <SPAN class="string token">"<br>"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> displayContent<SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>mapImgLyrUtil<SPAN class="punctuation token">.</SPAN>allSublayers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>sublayer<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
sublayer<SPAN class="punctuation token">.</SPAN>popupTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PopupTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> createContent<SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> sublayer<SPAN class="punctuation token">.</SPAN>name
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> sublayer<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
