I am trying to put together a map site and am having difficulty with putting graphics on the map. I followed the sandbox example but for some reason I cannot get anything to work on my app. I created a simple click event on the view just to try it. The click event fires OK (I have an alert in the function to add the graphic that shows the x,y values of the point, so I know the point isn't null either). I get the following error in the F12 console:
IE:
SCRIPT5007: Unable to get property 'type' of undefined or null reference
File: MapView.js, Line: 408, Column: 41
Chrome:
MapView.js:408 Uncaught TypeError: Cannot read property 'type' of undefined
at k.get [as isPolygonMarkerSymbol] (MapView.js:408)
at k._projectGeometry (MapView.js:411)
at k.render (MapView.js:409)
at e.renderChild (MapView.js:406)
at e.k.renderChildren (MapView.js:301)
at e.k.render (MapView.js:297)
at l.renderChild (MapView.js:332)
at l.k.renderChildren (MapView.js:301)
at l.k.render (MapView.js:297)
at l.render (MapView.js:330)
Below is the view event and javascript that is used to create the graphic:
view.on("click", function(event) {
var sPoint = {
x: event.x,
y: event.y
var pt = view.toMap(sPoint.x,sPoint.y); //this converts the point xy from screen points to map points (WKID 2868)
currentX = pt.x;
currentY = pt.y;
view.graphics.add(pt);
putPointOnMap();
//This is the first method I tried, like the sandbox example it assigns the point and style to the graphic and adds to the view
function putPointOnMap() {
var smsMarker = new SimpleMarkerSymbol({
color: [255,0,0],
outline: {
color: [0,0,255],
width:2
var pt = new Point({
x: currentX,
y: currentY
var ptGraphic = new Graphic({
geometry: pt,
symbol: smsMarker
window.alert(pt.x + "," + pt.y);
view.graphics.add(ptGraphic);
//I also tried this, creating a graphicslayer, adding the graphic to it, and adding it to the map. Same result
color: [255,0,0],
outline: {
color: [0,0,255],
width:2
x: currentX,
y: currentY
geometry: pt,
symbol: smsMarker
gLayer=new GraphicsLayer({});
glayer.add(ptGraphic);
map.add(gLayer);
Thank you in advance for any help you may be able to provide. I've checked everything over (syntax, capital letters, etc) and cannot find what the issue is.
Jeff
