I having trouble to save raster statistics value into csv or text format. Below is my working code. Below code only print the raster statistics value, but i am interested to save the output value to text or csv format.
I appreciate any help you can provide on the crucial bottom code.
Thank you
<SPAN class="keyword token">import</SPAN> arcpy
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"D:\2008A"</SPAN>
rasterList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListRasters<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> raster <SPAN class="keyword token">in</SPAN> rasterList<SPAN class="punctuation token">:</SPAN>
rasterObj <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Raster<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> raster
bands <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetRasterProperties_management<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"MEAN"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"MEAN VALUE: %s"</SPAN> <SPAN class="operator token">%</SPAN>bands
bands <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetRasterProperties_management<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"STD"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"STANDARD DEV: %s"</SPAN> <SPAN class="operator token">%</SPAN>bands
bands <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetRasterProperties_management<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"MINIMUM"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"MIN VALUE: %s"</SPAN> <SPAN class="operator token">%</SPAN>bands
bands <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetRasterProperties_management<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"MAXIMUM"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Max VALUE: %s"</SPAN> <SPAN class="operator token">%</SPAN>bands<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
