Hello,I have an application that displays the results of an Identify Task in a datagrid. I then utilize the OnRowClick Handler to zoom to the feature. I would like the feature that is being zoomed to from each row to be highlighted on the map. Any help would be greatly apprciated!! 🙂
function onRowClickHandler(evt){
Â
 } if (searchType == "Surveys") {
  var clickedTaxLotId = grid3.getItem(evt.rowIndex).DOCUMENT_N;
  var selectedTaxLot;
  dojo.forEach(map.graphics.graphics,function(graphic){
    if((graphic.attributes) && graphic.attributes.DOCUMENT_N === clickedTaxLotId){
   selectedTaxLot = graphic;
   //added this part to build infotemplate
    map.infoWindow.setTitle(graphic.getTitle());
    map.infoWindow.setContent(graphic.getContent());
                           return;
Â
  if ( selectedTaxLot.geometry.declaredClass == 'esri.geometry.Point' ) {
  map.centerAndZoom(taxLotExtent, 11)
                                     var sp = map.toScreen(selectedTaxLot.geometry);
  map.infoWindow.show(selectedTaxLot.geometry, map.getInfoWindowAnchor(sp));
  } else {
  //alert("Polygon");
  var taxLotExtent = selectedTaxLot.geometry.getExtent();
  var screenpoint = map.toScreen(selectedTaxLot.geometry.getExtent().getCenter());
  var mappoint = map.toMap(screenpoint);
   map.setExtent(taxLotExtent,true);
  map.infoWindow.show(taxLotExtent.getCenter(), map.getInfoWindowAnchor(screenpoint));
Â
Â
} else if (searchType == "PointName") {
  var clickedTaxLotId = grid4.getItem(evt.rowIndex).POINT_NAME;
  var selectedTaxLot;
  var highlightSymbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([25,50,225,0.3]));
    if((graphic.attributes) && graphic.attributes.POINT_NAME === clickedTaxLotId){
   return;
Â
  map.centerAndZoom(selectedTaxLot.geometry, 11)
  } else {
  //alert("Polygon");
   //map.centerAt(mappoint);
   map.centerAndZoom(selectedTaxLot.geometry,15);
 Â
