I have two functions `
createPoints(); and addClusters();
to create points and cluster points from JSON point values and I am switching the map presentation (Points<-->Cluster) by suing a Chechbox like :
if($("input[type='checkbox'][name='clusterPoints']").is(':checked')) {
createPoints();
}else{ addClusters();}
$("input[type='checkbox'][name='clusterPoints']").change(function(){
if($(this).is(':checked')){
map.removeLayer(clusterLayer);
map.graphics.show();
else{
map.graphics.hide();
addClusters();
}); now after switching from Cluster to Points, I am missing the points InfoTemplate(); (not poping up on points on click) but the Cluster PopupTemplate(s) work fine . Here is the how code:
function createPoints(){
for (var i = 0; i < mapInfo.length; i++) {
var project = mapInfo;
var point = new Point(project.Longitude, project.Latitude);
var pointSymbol = new SimpleMarkerSymbol();
pointSymbol.setStyle(SimpleMarkerSymbol.STYLE_CIRCLE);
pointSymbol.setSize(12);
var pointInfoTemplate = new InfoTemplate();
pointInfoTemplate.setTitle("Project Details");
pointInfoTemplate.setContent('<div class="list-group marker-info"> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Project</span><span class="col-md-3 marker-info-txt"><strong>'+project.ProjectID+'</strong></span></div></a> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Road Length</span><span class="col-md-3 marker-info-txt"><strong>'+project.RoadLength+'</strong></span></div></a> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Powerline Length</span><span class="col-md-3 marker-info-txt"><strong>'+project.PowerLineLength+'</strong></span></div></a> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Penstock</span><span class="col-md-3 marker-info-txt"><strong>'+project.Penstock+'</strong></span></div></a> <a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Installed Capacity</span><span class="col-md-3 marker-info-txt"><strong>'+project.InstalledCapacity+'</strong></span></div></a><a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Annual Firm Energy</span><span class="col-md-3 marker-info-txt"><strong>'+project.AnnualFirmEnergy+'</strong></span></div></a><a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Cost Of Energy</span><span class="col-md-3 marker-info-txt"><strong>'+project.CostOfEnergy+'</strong></span></div></a><a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Footprint</span><span class="col-md-3 marker-info-txt"><strong>'+project.Footprint+'</strong></span></div></a><a href="#" class="list-group-item"><div class="row"><span class="col-md-7 marker-info-txt">Cost Per Year</span><span class="col-md-3 marker-info-txt"><strong>'+project.CostPerYear+'</strong></span></div></a></div> ');
var pointGraphic = new Graphic(point, pointSymbol).setInfoTemplate(pointInfoTemplate);
points.push(pointGraphic);
for (i = 0; i < points.length; ++i) {
map.graphics.add(points);
function addClusters() {
var project=[];
project.push(mapInfo);
var photoInfo = [];
var wgs = new SpatialReference({
"wkid": 4326
photoInfo.data = arrayUtils.map(mapInfo, function(p) {
var latlng = new Point(parseFloat(p.Longitude), parseFloat(p.Latitude), wgs);
var webMercator = webMercatorUtils.geographicToWebMercator(latlng);
var attributes = {
"Project ID": p.ProjectID,
"Road Length": p.RoadLength,
"Powerline Length": p.PowerLineLength,
"Penstock": p.Penstock,
"Installed Capacity": p.InstalledCapacity,
"Annual Firm Energy": p.AnnualFirmEnergy,
"Cost Of Energy": p.CostOfEnergy,
"Footprint": p.Footprint,
"Cost Per Year": p.CostPerYear,
return {
"x": webMercator.x,
"y": webMercator.y,
"attributes": attributes
var popupTemplate = new PopupTemplate({
"title": "Project Details",
"fieldInfos": [{
"fieldName": "Project ID",
visible: true
"fieldName": "Road Length",
visible: true
"fieldName": "Powerline Length",
visible: true
"fieldName": "Penstock",
visible: true
"fieldName": "Installed Capacity",
visible: true
"fieldName": "Annual Firm Energy",
visible: true
"fieldName": "Cost Of Energy",
visible: true
"fieldName": "Footprint",
visible: true
"fieldName": "Cost Per Year",
visible: true
"mediaInfos": [{
"title": "",
"caption": "",
"type": "image",
"value": {
"sourceURL": "{Image}",
"linkURL": "{Link}"
clusterLayer = new ClusterLayer({
"data": photoInfo.data,
"distance": 100,
"id": "clusters",
"labelColor": "#fff",
"labelOffset": 10,
"resolution": map.extent.getWidth() / map.width,
"singleColor": "#888",
"singleTemplate": popupTemplate
var defaultSym = new SimpleMarkerSymbol().setSize(4);
var renderer = new ClassBreaksRenderer(defaultSym, "clusterCount");
var picBaseUrl = "http://static.arcgis.com/images/Symbols/Shapes/";
var blue = new PictureMarkerSymbol(picBaseUrl + "BluePin1LargeB.png", 32, 32).setOffset(0, 15);
var green = new PictureMarkerSymbol(picBaseUrl + "GreenPin1LargeB.png", 64, 64).setOffset(0, 15);
var red = new PictureMarkerSymbol(picBaseUrl + "RedPin1LargeB.png", 72, 72).setOffset(0, 15);
renderer.addBreak(0, 2, blue);
renderer.addBreak(2, 200, green);
renderer.addBreak(200, 1001, red);
clusterLayer.setRenderer(renderer);
map.addLayer(clusterLayer);
// close the info window when the map is clicked
map.on("click", cleanUp);
// close the info window when esc is pressed
map.on("key-down", function(e) {
if (e.keyCode === 27) {
cleanUp();
function cleanUp() {
map.infoWindow.hide();
clusterLayer.clearSingles();
function error(err) {
console.log("something failed: ", err);
window.showExtents = function() {
var extents = map.getLayer("clusterExtents");
if ( extents ) {
map.removeLayer(extents);
extents = new GraphicsLayer({ id: "clusterExtents" });
var sym = new SimpleFillSymbol().setColor(new Color([205, 193, 197, 0.5]));
arrayUtils.forEach(clusterLayer._clusters, function(c, idx) {
var e = c.attributes.extent;
extents.add(new Graphic(new Extent(e[0], e[1], e[2], e[3], map.spatialReference), sym));
}, this);
map.addLayer(extents, 0);
createPoints();
else{
addClusters();
}); Can you please let me know why this is happening and how I can fix this? Am using correct functions ` map.graphics.hide();` and map.removeLayer(clusterLayer); to clear map for next presentation in check box switch?
