I am trying to add webappbuilder in Portal for ArcGIS 10.6.1 from the content - add item - add application
the register button is not visible .
If my portal n webappbuilder is on same server the register button will not visible is it??
as per the research got the below info
Note:
The Register option is not available if the app is hosted on the same web server as the portal's web adaptor. For instructions on how to register these apps, see Esri technical article 44907.
should we run the webappbuilder in different machine than the Portal for ArcGIS hosted machine .
