Hi All,
We are using ArcGIS GEP 10.2.2 hangs intermittently i.e where input data is not getting polled. Input status "STARTED" but there is no data or count is not getting increased. when I check the log below is the message. Once I restart the GeoEvent service , things are working fine. I am not sure what could be the reason.
error while deleting features in feature service GeoTab Delete String is f=json&rollbackOnFailure=true&where=DATETIMESTAMP<'2015-01-26 15:52:43' java.io.IOException: {"error":{"code":500,"message":"Unable to complete operation.","details":["Unable to perform deleteFeatures operation."]}} at com.esri.ges.transport.featureService.FeatureServiceOutboundTransport.validateResponse(FeatureServiceOutboundTransport.java:720)[253:com.esri.ges.framework.transport.featureservice-transport:10.2.2] at com.esri.ges.transport.featureService.FeatureServiceOutboundTransport.cleanup(FeatureServiceOutboundTransport.java:561)[253:com.esri.ges.framework.transport.featureservice-transport:10.2.2] at com.esri.ges.transport.featureService.FeatureServiceOutboundTransport.access$100(FeatureServiceOutboundTransport.java:42)[253:com.esri.ges.framework.transport.featureservice-transport:10.2.2] at com.esri.ges.transport.featureService.FeatureServiceOutboundTransport$CleanupThread.run(FeatureServiceOutboundTransport.java:622)[253:com.esri.ges.framework.transport.featureservice-transport:10.2.2]
In addition I see more number of below warnings as well.
| org.apache.http.impl.auth.HttpAuthenticator | KERBEROS authentication error: No valid credentials provided (Mechanism level: Failed to find any Kerberos tgt) | Wed Feb 25 13:54:49 CST 2015 | WARN |
| org.apache.http.impl.auth.HttpAuthenticator | NTLM authentication error: Credentials cannot be used for NTLM authentication: org.apache.http.auth.UsernamePasswordCredentials | Wed Feb 25 13:54:49 CST 2015 | WARN |
| org.apache.http.impl.auth.HttpAuthenticator | NEGOTIATE authentication error: No valid credentials provided (Mechanism level: No valid credentials provided (Mechanism level: Failed to find any Kerberos tgt)) |
I am also looking for an alert message to be set up for these kind of situations, any clue?
