I am looking for a way to undo edits such as move, scale and rotate of existing graphics on the map. So far I've tried to undo it in the same way as we currently undo 'draw' operations:
var editToolbar = new Edit(map);
editToolbar.on("scale-stop, vertex-move-stop", function (evt) {
var operation = new CustomOperation.Add({
graphicsLayer: selectedGraphicsLayer,
addedGraphic: evt.graphic
undoManager.add(operation);
});However this undoes the action that happened directly previous to the 'edit', which in our case was 'draw' and removes the graphic from the map. Am I missing something or should I be using a different method altogether?
I'm using following classes:
Edit - Edit | API Reference | ArcGIS API for JavaScript
UndoManager - UndoManager | API Reference | ArcGIS API for JavaScript
