My searchwidget is working alright, it displays the search with a popup template. The problem now is to get the result of the search as a json object or a table.
I have search the api references, and its the search-complete that returns search as an object. my code isn't right. Any help please see below,
// Search
var search = new Search({
view: view
search.defaultSource.withinViewEnabled = true; // Limit search to visible map area only
view.ui.add(search, "top-right"); // Add to the map
// Add the trailheads as a search source
search.sources.push({
featureLayer: trailsLayer,
searchFields: ["Postcode", "UPRN", "ADDRESS" ],
displayField: "Postcode",
exactMatch: false,
outFields: ["*"],
resultGraphicEnabled: true,
placeholder: "example: CM2 0HU",
popupTemplate: { // autocasts as new popupTemplate()
title: "Post Code: {Postcode}</br>UPRN: {UPRN}</br>ADDRESS: {ADDRESS}",
overwriteActions: true
featureLayer: trailsLayerr,
exactMatch: false,
outFields: ["*"],
function searchcomplete( search-complete) {
view.popup.open({
activeSourceIndex: Number,
errors: Error[],
numResults: Number,
searchTerm: String,
results: Object[],
searchWidget.on("search-complete", function(event){
// The results are stored in the event Object[]
console.log("Results of the search: ", event);
});</script>
</head>
<body>
<div id="viewDiv"></div>
