I have created a very basic script (with the help of others) that uses a searchCursor to pull data from a feature class and, in theory, add that data to a text file.I think I almost have it but I am still getting a few errors that I cannot figure out (I am completely new to python and am at a complete loss now).The first error I get is as follows:Traceback (most recent call last): File "G:\Olson-Murphy_Week10\Scripts\MaterialSearch2.py", line 10, in <module> Qry = "Material = " + '%s' %materialTypeNameError: name 'materialType' is not definedFailed to execute (MaterialReport).By removing "%materialType" from the script i get this error to go away but then I am faced with another:Traceback (most recent call last): File "G:\Olson-Murphy_Week10\Scripts\MaterialSearch2.py", line 14, in <module> MaterialSearch = arcpy.SearchCursor(fc,Qry, fields = "Material;Diameter;System") File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\__init__.py", line 1133, in SearchCursor return gp.searchCursor(dataset, where_clause, spatial_reference, fields, sort_fields) File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 359, in searchCursor self._gp.SearchCursor(*gp_fixargs(args, True)))RuntimeError: ERROR 999999: Error executing function.Failed to execute (MaterialReport).My code can be found below. Anyone have any suggestions? (this code someone else did say worked on their machine so I am at a total loss)
import arcpy
# Set workspace
arcpy.env.workspace = r"G:\Olson-Murphy_Week10\SouthFloridaNaturalGas.gdb"
#Estabslish input feature class
fc = r"G:\Olson-Murphy_Week10\SouthFloridaNaturalGas.gdb\Mains"
# Establish materials search for tool
# Create cursor to search gas mains by material
#Define output
outReport = arcpy.GetParameterAsText(1)
#Open the report text file in write mode
file = open (outReport, "w")
#Add Header lines to report text file
file.write("Mains found in this report include:\n")
file.write("Material:" + Qry + "\n")
#Results of SearchCursor
for row in MaterialSearch:
rptMat = str(row.getValue("Material"))
rptDiam = str(row.getValue("Diameter"))
rptSys = str(row.getValue("System"))
file.write(rptMat + " " + rptDiam + " " + rptSys + "\n")
del MaterialSearch, row
