I have a project that let's the user change which attribute field is used in the display. It's based on the sample https://developers.arcgis.com/javascript/jssamples/renderer_dynamic_layer_change_attribute.html For the legend, I'm creating it if it doesn't exist, but if it does, then I just want it to refresh. My problem is that the title is based on a variable, defined based on the change event of the FilteringSelect list of fields. When I change the field, the legend itself updates, but it still has the title from its initial creation.
Can I change just the title? It doesn't seem to be honoring my title definition when I specify legend.refresh(). In this example, fields is the array of attributes from my layer and fieldChoice is the selected item from the FilteringSelect.
domConstruct.empty("legendDiv");
if (!legend){
legend = new Legend({
map: map,
layerInfos: [{ "layer": featureLayer, "title": fields[fieldChoice] }]
},"legendDiv");
legend.startup();
}else{
legend.refresh();
