Within the Geocoder Widget.js file, _initGeocoder function, if I add the following line:
this.own(on(geocoder, "clear", lang.hitch(this, "clearResults")));
and then add the corresponding "clearResults" function, I am able to clear the map of any graphic selection and/or popup. However, I want to accomplish this task within another widget and not modify the original geocoder widget. Within my other widget, I know I need to use aspect but not quite sure if I should use .before or .after. I think .before makes more sense, but I'm not clear how to incorporate the line of code above into the _initGeocoder function and then call the clearResults function from within my widget. This seems like an easy task but I can't seem to get the syntax right. Any help/thoughts would be great!
