Hi, I want to build an arcade expression that will count the number of points in a polygon layer.
So for example I have a polygon layer called "Data Zones" and a point layer called "Bus Stops". I want to count the number of Bus Stops that are in each Data Zone. Both Layers will be in the same web map.
I believe I have to use the Intersects and Count functions and the expression has to be in the Polygon layer , I just can't can't get an expression to successfully work.
Thanks in advance
