When I instantiate an extent, I provide the min/max coordinates to the Extent constructor as such
{xMin: -104.6279632, xMax: -103.2536728, yMin: 32.1424875714, yMax: 32.96790257160003}
However when I view the Extent obj instance, the min/max values are now magnitudes larger than the values I've passed:
- xmax:-11460263.863552293
- xmin:-11681014.001239965
- ymax:3885914.941853233
- ymin:3787158.301308748
How does the input min/max coordinates related to the min/max coordinates on the Extent instance?
I'm trying to cache the Extent after view becomes stationary. As such, I'm caching the larger min/max pairs from the extent object. This value can not be subsequently used to re-instantiate an Extent via the constructor method.
Is there some translation algorithm to map between the input min/max and the instantiated min/max? Thanks
