Hi, I wonder if it is possible to calculate the visibility of a flashing obstruction light on the top a wind turbine, given that there is a shield below the lamp that prevents emission of light at certain angles (for example 20 degrees to each side of the bottom of the light source, see attached drawing)? If the light was emitted in all directions, this would be an easy task. But it is possible to add conditions like this, and in case the answer is yes: How? Thanks in advance for any hints and tips!
