Hi there -
We've been given an ArcGIS Runtime geodatabase (attached) and need to convert it to a file geodatabase to use it in ArcMap.
I'm assuming that we can use the "Copy Runtime Geodatabase To File Geodatabase" tool to accomplish this. However, the conversion fails. It's possible that the source geodatabase file is corrupt, but also wanted to ask the community if this is the correct workflow, since this is not something I use very often.
Thank you!
