I have not worked with Tiled Services much. I have successfully created and added a tiled service layer with a custom tiling scheme, however the projection I specified did not get applied to the service. It defaulted to 102719.The projection is incorrect when I check the REST endpoint. It leads to projection problems when manipulating the map in my map. How do I fix this?
Arjun
