By default, the javascript popup launches on any click regardless of whether there is resulting data or not. I am trying too develop a map in which a click on a location which has no data will not launch the popup. There is a thread on this (How to NOT SHOW/HIDE infowindow/popup if identify results = No Info Avai.?â ) which shows how to do this using an event task but this is not a complete working sample so i am trying to fill in the blanks. I have my map working in the sandbox, but when I try to introduce an if (response.length > 0) { statement (line 118) to limit when the popup appears I get no popup regardless of where I click. Any ideas on what is wrong with the code below?
Cheers,
Ben
if (reasponse.length > 0) { if (response.length > 0) {
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Identify with Popup</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
<style>
html, body, #map {
height:100%;
width:100%;
margin:0;
padding:0;
</style>
<script src="http://js.arcgis.com/3.14/"></script>
<script>
require([
"esri/map",
"esri/InfoTemplate",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/tasks/IdentifyTask",
"esri/tasks/IdentifyParameters",
"esri/dijit/Popup",
"dojo/_base/array",
"dojo/dom-construct",
"dojo/domReady!",
"esri/dijit/Search",
"esri/dijit/HomeButton"
function (
Map,
InfoTemplate,
ArcGISDynamicMapServiceLayer,
IdentifyTask,
IdentifyParameters,
Popup,
arrayUtils,
domConstruct,
Search,
HomeButton
var identifyTask, identifyParams;
var popup = new Popup({}, domConstruct.create("div"));
//popup.visibleWhenEmpty = false;
//popup.hideDelay = 0;
var map = new Map("map", {
basemap: "topo",
center: [147, -33.5],
zoom: 6,
logo:false,
showAttribution: false,
infoWindow: popup
map.on("load", mapReady);
var templateRivers = new InfoTemplate();
templateRivers.setTitle("<b>${LocationUpper}</b>");
templateRivers.setContent("<b>${River}</b><br><b>Flow:</b> ${Flow:NumberFormat(places:0)} ML/day<br><b>Level:</b> ${Level_:NumberFormat(places:2)} m<br><b>Status:</b> ${Status}<br><b>Updated on: </b> ${Last_Update}");
var templateStorages = new InfoTemplate();
templateStorages.setTitle("<b>${LocationUpper}</b>");
templateStorages.setContent("<b>${River}</b><br><b>Storage:</b> ${Percentage:NumberFormat(places:0)} %<br><b>Level:</b> ${Level_:NumberFormat(places:2)} m<br><b>Status:</b> ${Status}<br><b>Updated on: </b> ${Last_Update}");
var templateCatchment = new InfoTemplate();
templateCatchment.setTitle("<b>Sydney's Drinking Water Catchment</b>");
templateCatchment.setContent("<br/><a href='http://www.waternsw.com.au/supply/greater-sydneys-dam-levels' target='_blank'>Click here for detailed information about Sydney's drinking water storages</a>");
var parcelsURL = "http://maps.waternsw.com.au:6080/arcgis/rest/services/Water/HydrometricService/MapServer";
map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL,
{ opacity: 0.9 }));
function mapReady () {
map.on("click", executeIdentifyTask);
//create identify tasks and setup parameters
identifyTask = new IdentifyTask(parcelsURL);
identifyParams = new IdentifyParameters();
identifyParams.tolerance = 10;
identifyParams.returnGeometry = false;
identifyParams.layerIds = [0,1,2,3];
identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = map.width;
identifyParams.height = map.height;
function executeIdentifyTask (event) {
identifyParams.geometry = event.mapPoint;
identifyParams.mapExtent = map.extent;
var deferred = identifyTask
.execute(identifyParams)
.addCallback(function (response) {
// response is an array of identify result objects
// Let's return an array of features.
map.infoWindow.show(evt.mapPoint);
return arrayUtils.map(response, function (result) {
var feature = result.feature;
var layerName = result.layerName;
feature.attributes.layerName = layerName;
if (layerName === 'Hydrometric Service - Rivers') {
feature.setInfoTemplate(templateRivers);
else if (layerName === 'HydrometricService - Storage') {
feature.setInfoTemplate(templateStorages);
else if (layerName === 'Declared Catchment (WNSW)') {
feature.setInfoTemplate(templateCatchment);
return feature;
map.infoWindow.setFeatures([deferred]);
</script>
</head>
<body>
<div id="map"></div>
</body>
</html>
