I have 2 .sid images that we use in ArcPad. Where the images overlap, there is a blackout area where there is a '0' value from the projections. In arcMap, I can simply symbolize a '0' value as null and eliminate the black-out. They are both projected into the same state plane system, even though the boundary is through one of the images. This means that the projection extent is exceeded, and therefore the images cannot be mosaiced. I cannot reproject one nor the other both because of the boundary of the State-Plane system, and everything has to have the same coordinate system in ArcPad. Any suggestions?
Thank you!!
