On ArcGIS Pro 2.4.2 running the Optimized Hot Spot analysis crashes ArcGIS Pro. No warning or error message - literally disappears. As a test I ran Hot Spot Analysis (non-optimized), and it produced expected results. The crash occurs when Optimized Hot Spot Analysis is run on different layers (so it is not unique to one specific layer). No error logs are produced - they would normally appear in .../AppData/Roaming/Esri/errorlogs or .../AppData/Local/Esri/errorlogs
The error is consistent - it fails every time on every layer. The analysis starts normally and progresses to the point of performing Anselin Local Moran's I calculations, which reaches somewhere over 95% complete, then ArcGIS Pro instantly disappears - no warning, error message, or error log of any kind
System: AMD A10-8700p processor with 12G memory.
OS: Windows 10 Home version 1809 64bit (Current with all updates)
No other significant software running simultaneously other than a standard browser.
