I am trying to clip a raster and save the output with a predefined name to a file geodatabase which will be defined by the user as a parameter. I have tried two different angles, and both give me errors.
Trial 1
# Import modules
import arcpy
from arcpy import env
from arcpy.sa import *
# Input Parameters
Boundary = arcpy.GetParameterAsText(0)
InRaster = arcpy.GetParameterAsText(1)
GDBLoc = arcpy.GetParameterAsText(2) # data type set as workspace
# Clip Raster
Raster = arcpy.Clip_management(InRaster, "", "in_memory", Boundary, "0", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
RasName = ("GDBLoc" + "\\PredefinedName")
Raster.save(RasName)
Results in:
AttributeError: 'Result' object has no attribute 'save'
Trial 2
# Import modules
import arcpy
# Input Parameters
# Clip Raster
Raster = arcpy.Clip_management(InRaster, "", "GDBLoc + \\PredefinedName", Boundary, "0", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
Results in:
ExecuteError: ERROR 999999: Error executing function.
