Is it possible to create a rpk from a rule file that uses several subscripts (separate cga files) through import? I tried several times and it seems that the rpk can only be created for a single cga. If you have 'import'-statements in the cga the created rpk doesn't work, it is looking for the imported scripts which it can't find. How can I solve this problem?
