I'm trying to figure out what is wrong with my For loop. To make it easy, I stripped down the code and this is what it supposed to do:- Make sure there are Single Tables in TOC (if true, continue)- Check if the Subdivision Plans table is in TOC. - If Subdivision Plans table is in TOC, show "Subdivision Plans Table Found" message- If Subdivision Plans table is not in TOC, show "Subdivision Plans Table Not Found" messageIf the Subdivision Plans table is in the TOC, everything works as it should. But, if the Subdivision Plans table isn't found, it goes to the Catch Exception error, instead of the "Subdivision Plans Table Not Found" message. Why?
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Try
' Variables declarations
Dim ANBLS As String = Me.ComboBox1.Text.Trim
Dim pMap As IMap = My.ArcMap.Document.ActiveView
Dim queryFilter As String = "FileNumber = '" + ANBLS + "'"
Dim tableName As String = "CSJGISSDE.GISDATA.Subdivision_Plans_Table"
Dim pStTabColl As IStandaloneTableCollection
Dim foundTable As Integer = 0
pStTabColl = pMap
' Check if there are tables are in TOC
If pStTabColl.StandaloneTableCount <> 0 Then
' Check if Subdivision Plans table is in TOC
For i As Integer = 0 To pStTabColl.StandaloneTableCount
If (pStTabColl.StandaloneTable(i).Name = tableName) Then
MsgBox("Subdivision Plans Table found")
foundTable = 1
Exit For
End If
Next i
Else
MsgBox("No tables found")
Return
End If
' Subdivision Plans Table Not found in the TOC
If foundTable = 0 Then
MsgBox("Subdivision Plans Table Not found")
Return
End If
' If all fails...
Catch ex As Exception
MsgBox("This action cannot be done. Save your project, then restart ArcMap.")
End Try
End Sub
