For reference, this is the data I want to access: Airports
I am looking to pull only certain parts of the data available from that reference based on what a user searches for. In particular, the airport name, code, and latitude/longitude. I want to then display that information on a Google map, not an ArcGIS map.
I have spent this week assuming I could do that via jQuery/AJAX, but I am beginning to think I have a misunderstanding of what AJAX is meant for. An example would be a user types in "LAX" and the returned result plots a location on a Google map and then displays the airport information available, such as address, phone number, etc.
Based on that, I have some questions:
1.) Can I use jQuery/AJAX to achieve what I want to do?
2.) If yes, how do you query that data set? There are two types of files (GeoService and GeoJSON)
3.) The code I have thus far, and I'll post it if I'm at least on the right track, continually returns all of a particular data field, such as all airport codes. It's not limiting it to only what the user searched for. And this is on a locally hosted JSON file, not the ArcGIS server.
Thank you for your help.
