I am trying to bring in multiple raster layers by using the multivalue parameter properties, however the script fails and states the dataset does not exist or is not supported. I have attached the error message as well as the script I am using. The raster layers are normally brought in directly from the TOC.
Error
Messages
Executing: CalcCompRasters Image1;Image2;Image3;Image4 S:\AVWorks\Scratch.gdb\avgtest
Start Time: Mon Jan 25 11:13:38 2016
Running script CalcCompRasters...
Failed script CalcCompRasters...
File "S:\Data\My Toolboxes\MyScripts\Calculate Composite Rasters.py", line 24, in <module>
OutAvgTemp = CellStatistics(InRasters, "MEAN", "DATA")
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\sa\Functions.py", line 2967, in CellStatistics
ignore_nodata)
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\sa\Utils.py", line 53, in swapper
result = wrapper(*args, **kwargs)
File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\sa\Functions.py", line 2963, in Wrapper
[function] + Utils.flattenLists(in_rasters_or_constants))
RuntimeError: ERROR 000732: Input Raster: Dataset Image1;Image2;Image3;Image4 does not exist or is not supported
Failed to execute (CalcCompRasters).
Failed at Mon Jan 25 11:13:40 2016 (Elapsed Time: 1.97 seconds)
Below is the Script I am using. This will be the start of a larger script, but until I get past this I won't add more to it.
# Import arcpy module
import arcpy
from arcpy.sa import *
# Script arguments
InRasters = arcpy.GetParameterAsText(0)
OutAvg = arcpy.GetParameterAsText(1)
# Process: Cell Statistics - Avg
OutAvgTemp.save(OutAvg)
