I am trying to create a feature class using C# and ArcObjects and it needs to have a raster field. However I am getting an error when I try to create the feature class.Here is a snippet of the code I am using.public IFields CreateFields(ISpatialReference spatialReference) { IFields fields = new FieldsClass(); IFieldsEdit fieldsEdit = (IFieldsEdit)fields; fieldsEdit.FieldCount_2 = 3; //Create the Object ID field. IField fieldUserDefined = new Field(); IFieldEdit fieldEdit = (IFieldEdit)fieldUserDefined; fieldEdit.Name_2 = "OBJECTID"; fieldEdit.AliasName_2 = "OBJECT ID"; fieldEdit.Type_2 = esriFieldType.esriFieldTypeOID; fieldsEdit.set_Field(0, fieldUserDefined); // Create the Shape field. fieldUserDefined = new Field(); fieldEdit = (IFieldEdit)fieldUserDefined; // Set up the geometry definition for the Shape field. IGeometryDef geometryDef = new GeometryDefClass(); IGeometryDefEdit geometryDefEdit = (IGeometryDefEdit)geometryDef; geometryDefEdit.GeometryType_2 = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint; // By setting the grid size to 0, you're allowing ArcGIS to determine the appropriate grid sizes for the feature class. // If in a personal geodatabase, the grid size will be 1000. If in a file or ArcSDE geodatabase, the grid size // will be based on the initial loading or inserting of features. geometryDefEdit.GridCount_2 = 1; geometryDefEdit.set_GridSize(0, 0); geometryDefEdit.HasM_2 = false; geometryDefEdit.HasZ_2 = false; //Assign the spatial reference that was passed in, possibly from //IGeodatabase.SpatialReference for the containing feature dataset. if (spatialReference != null) { geometryDefEdit.SpatialReference_2 = spatialReference; } // Set standard field properties. fieldEdit.Name_2 = "SHAPE"; fieldEdit.Type_2 = esriFieldType.esriFieldTypeGeometry; fieldEdit.GeometryDef_2 = geometryDef; fieldEdit.IsNullable_2 = true; fieldEdit.Required_2 = true; fieldsEdit.set_Field(1, fieldUserDefined); fieldUserDefined = new Field(); fieldEdit = (IFieldEdit)fieldUserDefined; fieldEdit.Name_2 = "PHOTO"; fieldEdit.AliasName_2 = "Attach a Photo"; fieldEdit.Editable_2 = true; fieldEdit.IsNullable_2 = false; fieldEdit.Type_2 = esriFieldType.esriFieldTypeRaster; fieldsEdit.set_Field(2, fieldUserDefined);After the fields have been defined, the following method is called to create the feature class.public IFeatureClass CreateFeatureDatasetFeatureClass(IFeatureDataset featureDataset, String featureClassName, IFields fieldsCollection, String shapeFieldName) { IFeatureClassDescription fcDesc = new FeatureClassDescriptionClass(); IObjectClassDescription ocDesc = (IObjectClassDescription)fcDesc; // Use IFieldChecker to create a validated fields collection. IFieldChecker fieldChecker = new FieldCheckerClass(); IEnumFieldError enumFieldError = null; IFields validatedFields = null; fieldChecker.ValidateWorkspace = featureDataset.Workspace; fieldChecker.Validate(fieldsCollection, out enumFieldError, out validatedFields); // The enumFieldError enumerator can be inspected at this point to determine // which fields were modified during validation. IFeatureClass featureClass = featureDataset.CreateFeatureClass(featureClassName, validatedFields, ocDesc.InstanceCLSID, ocDesc.ClassExtensionCLSID, esriFeatureType.esriFTSimple, fcDesc.ShapeFieldName, ""); return featureClass; }On the last line of code I get an error: Value does not fall within the expected range.If I change the code to create the field,from :fieldEdit.Type_2 = esriFieldType.esriFieldTypeRaster;to:fieldEdit.Type_2 = esriFieldType.esriFieldTypeString;It works. But I obviously don't want a string field, I would like to have a raster field.Can someone please help me out, that would be greatly appreciated.Thanks!
