I have a File Geodatabase that has many fields in it. Some of these fields have coded domain values. This has been working perfectly for months. I just added an additional code for a specific domain, and now none of the coded values work. It used to have the dropdown menu options for the fields that had coded values and now when I am in an edit session - there is not a dropdown menu, instead it it just allowing me to type regularly. I have tried to delete the last coded value to see if that would work - it did not. I have tried all the logical things (like restarting ArcMap, ArcCatalog, etc.). Has anyone had this issue? If so, how did you fix it?
Thank you!!
Sandy Smith
