I am trying to implement arcade expressions using the latest version of the quartz sdk for Android. I am not having any success. First off I want to confirm that this is supported in the Android runtime sdk at this time? References in the Arcade matrix only mention "ArcGIS Runtime" not all the runtimes individually. I see no mention of arcade specifically in the Android documentation API or sample code, whereas in the ios SDK resources I at least see some mention of it.
It seems like it is, or should be supported as the Collector beta for Android does evaluate arcade expressions as expected. However, after digging into this a bit I am starting to think they are doing something outside of the SDK directly. Is this the case or am I not seeing something?
Any info, resources or sample code would be much appreciated.
