when i try use carto and grid my map i see below error ; it's happen when i want create a Graticule : Graticule mapGrid = new Graticule();
i installed arcmap10.2 and also used both jdk 64&32bit and eclipse 64bit; i run some samples that is in arcobject but i couldn't creat a grid; my code is exactly that is said in this link(createGrid() function).
i followed some guide links but i couldn't solve it,
thanks .
and the error is:
Java version : 1.8.0_51 (Oracle Corporation) x86
Rendering engine : DirectX
java.lang.UnsatisfiedLinkError: no ntvauth in java.library.path
Could not load native libraries.
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1865)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at com.esri.arcgis.interop.NativeLoader.loadLibrary(Unknown Source)
at com.esri.arcgis.interop.NativeAuth.c(Unknown Source)
at com.esri.arcgis.interop.c.a(Unknown Source)
at com.esri.arcgis.interop.RpcConnectionHandler.a(Unknown Source)
at com.esri.arcgis.interop.hb.a(Unknown Source)
at com.esri.arcgis.interop.Dispatch.createDispatch(Unknown Source)
at com.esri.arcgis.interop.Dispatch.<init>(Unknown Source)
at com.esri.arcgis.carto.IMapGridProxy.<init>(Unknown Source)
at com.esri.arcgis.carto.IGraticuleProxy.<init>(Unknown Source)
at com.esri.arcgis.carto.Graticule.<init>(Unknown Source)
at GridApp.CartoTest(GridApp.java:225)
at GridApp.createUI(GridApp.java:215)
at GridApp$1.run(GridApp.java:301)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError: com.esri.arcgis.interop.NativeAuth.getNegociateMessage()[B
at com.esri.arcgis.interop.NativeAuth.getNegociateMessage(Native Method)
at com.esri.arcgis.interop.NativeAuth.a(Unknown Source)
at com.esri.arcgis.interop.tb.b(Unknown Source)
at com.esri.arcgis.interop.tb.a(Unknown Source)
at com.esri.arcgis.interop.RpcConnectionHandler.<init>(Unknown Source)
