I'll preface this by saying I'm pretty weak on cursors but trying to boot camp myself to basic proficiency.
I'm trying to create a simple script that will take a point feature class and create lines from them. These points are the start point of the the line and for sake of demonstration here, the endpoints are defined mathematically from them. Simple 2-point lines.
startingPt = "STARTING_POINTS" #point feature layer in MXD
fields = ['SHAPE@X', 'SHAPE@Y']
point = arcpy.Point()
array = arcpy.Array()
featureList = []
insert = arcpy.da.InsertCursor(r"D:\Temp\Lines.shp",['SHAPE@'])
with arcpy.da.SearchCursor(startingPt, fields) as cursor:
for row in cursor:
startX = row[0]
startY = row[1]
array.add(point)
endX = startX + 660
endY = startY + 660
array.add(point)
polyline = arcpy.Polyline(array)
insert.insertRow([polyline])
print "Start: {},{} End: {},{}".format(startX,startY,endX,endY)
del cursor
The script successfully writes rows to the target, but the geometry is empty. I'm sure there is a simple (and stupid) mistake in the code. Any help is appreciated and I'm totally open to suggestions. I'd rather not have a copy features or append operation but just an insert unless my logic is totally flawed here.
Thanks!
