Hi All,I installed ArcGIS 10.2.1 on my Windows 8.1 Pro machine and am having problems.I can open/display maps, and do many of my 'normal mapping' stuff.However, every single tool that I have tried in ArcToolBox 'crashes' ArcMap. I put crash in quotes because it ArcMap just disappears.I had noticed that some people complained that newer versions of Python installed on the machine interfere so I uninstalled by Python 3.2. I think that I am now using the correct Python (see code below).What else could be causing my problems ? What seems odd is that when I open a command window and type 'python -V' it comes back as not a recognized commandI typed the following into my ArcMap python window. I believe this means that it is running correctly. >>> import sys
>>> for pypath in sys.path:
... print pypath
C:\WINDOWS\SYSTEM32\python27.zip
c:\program files (x86)\arcgis\desktop10.2\arcpy
C:\Python27\ArcGIS10.2\Lib
C:\Python27\ArcGIS10.2\DLLs
C:\Python27\ArcGIS10.2\Lib\lib-tk
C:\WINDOWS\System32
C:\Program Files (x86)\ArcGIS\Desktop10.2\bin
C:\Python27\ArcGIS10.2\lib\site-packages
C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy
C:\Program Files (x86)\ArcGIS\Desktop10.2\ArcToolbox\Scripts
>>> print 'Running against: %s' %sys.version
Running against: 2.7.5 (default, May 15 2013, 22:43:36) [MSC v.1500 32 bit (Intel)]
Thanks in advance !
