Can you please let me know how we can enable ArcGIS JavaScript API to use custom ZoomIn function?
For example let's say I have a code Like
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>button</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>zoom-to-point<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">></SPAN></SPAN> Zoom To <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>button</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
and in Js Part
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#zoom-to-point"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'click'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> zoomLat <SPAN class="operator token">=</SPAN> <SPAN class="number token">49.2898</SPAN>
<SPAN class="keyword token">var</SPAN> zoomLong <SPAN class="operator token">=</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">123.1364</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">zoomTo</SPAN><SPAN class="punctuation token">(</SPAN>zoomLat<SPAN class="punctuation token">,</SPAN>zoomLong <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>As you know we have not such a .zoomTo function in API so can you please let me know how can I get it done?
