My map will not load and I get this in the console when using Edge.
<SPAN class="punctuation token">[</SPAN>esri<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">.</SPAN>TileLayer<SPAN class="punctuation token">]</SPAN> #<SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> Failed to load layer <SPAN class="punctuation token">(</SPAN>title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Aerial'</SPAN><SPAN class="punctuation token">,</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'16be45292c8-layer-0'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">[</SPAN>request<SPAN class="punctuation token">:</SPAN>server<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN> Unable to load https<SPAN class="punctuation token">:</SPAN><SPAN class="operator token">/</SPAN><SPAN class="operator token">/</SPAN>maps<SPAN class="punctuation token">.</SPAN>npdc<SPAN class="punctuation token">.</SPAN>govt<SPAN class="punctuation token">.</SPAN>nz<SPAN class="operator token">/</SPAN>arcgis<SPAN class="operator token">/</SPAN>rest<SPAN class="operator token">/</SPAN>services<SPAN class="operator token">/</SPAN>Aerial<SPAN class="operator token">/</SPAN>MapServer<SPAN class="operator token">?</SPAN>f<SPAN class="operator token">=</SPAN>json status<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
I was getting this while using ArcGis JS 3x and so I converted the map to 4x but I still get this error and the map won't load.
