arcpy<SPAN class="punctuation token">.</SPAN>CreateDomain_management<SPAN class="punctuation token">(</SPAN>path<SPAN class="operator token">+</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="operator token">+</SPAN>gdb_name<SPAN class="operator token">+</SPAN><SPAN class="string token">".gdb"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOM_XYACCURACY_NPS2016"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Accuracy"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"CODED"</SPAN><SPAN class="punctuation token">)</SPAN>
XYACCURACYDict <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"Unknown"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"Unknown"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"<5cm"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"<5cm"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">">=5cm and <50cm"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">">=5cm and <50cm"</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="string token">">=50cm and < 1m"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">">=50cm and < 1m"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">">=1m and <5m"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">">=1m and <5m"</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="string token">">=5m and <14m"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">">=5m and <14m"</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="string token">">=14m"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">">=14m"</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Scaled"</SPAN><SPAN class="punctuation token">:</SPAN> "Scaled<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">for</SPAN> code <SPAN class="keyword token">in</SPAN> XYACCURACYDict<SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddCodedValueToDomain_management<SPAN class="punctuation token">(</SPAN>path<SPAN class="operator token">+</SPAN><SPAN class="string token">"\\"</SPAN><SPAN class="operator token">+</SPAN>gdb_name<SPAN class="operator token">+</SPAN><SPAN class="string token">".gdb"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOM_XYACCURACY_NPS2016"</SPAN><SPAN class="punctuation token">,</SPAN> code<SPAN class="punctuation token">,</SPAN> XYACCURACYDict<SPAN class="punctuation token">[</SPAN>code<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Throws an error when in a Pro 2.1.2 toolbox, but I'm able to create a domain with the same values containing ">" character. Any idea on how to make this work? Can't change the values, the codes and the values are "etched in stone" as they say.
So Posting this to geonet, as I hit save, highlighted my really mickey-mouse syntax error, a missing "..........
