Hello everyone,
I'm trying to have a print widget in my application. I'm using PrintTask. here's the code:
var template = new PrintTemplate();
template.exportOptions = {
width: 500,
height: 400,
dpi: 96
template.format = "PDF";
template.layout = "MAP_ONLY";
template.preserveScale = false;
params = new PrintParameters();
params.map = map;
params.template = template;
params.outSpatialReference = map.spatialReference;
printTask = new PrintTask('url', { async: true });
And then whenever the user clicks on the print button it will go to the following function
function print() {
printTask.execute(params, printResult, printError);
function printResult(result) {
window.open(results.value.url, "_blank");
function printError(result) {
alert(result);
When I run the application and click on print, it doesn't do anything(doesn't bring an error either)
anyone can help please? I would really appreciate it.
