Hello,I've been working on a script that simply display a marker on a map which let a pop up appear with some infos on it.My problem is that my pop up "pop" and instantly "unpop", I've noticed that if I replace the webmap id by a simple map creation, it works..I can't understand why it doesn't work, here's my code :Any kind of help/tips would be appreciated, thanks 🙂var map, webmapId = "map id"; require([ "esri/map", "esri/arcgis/utils", "dojo/domReady!" ], function (Map, arcgisUtils) { arcgisUtils.createMap(webmapId, "mapDiv").then(function (response) { map = response.map; map.on("load", function(){ map.infoWindow.resize(250,100); }); var point = new esri.geometry.Point(8.7386350, 41.9192290); point = esri.geometry.geographicToWebMercator(point); var symbol = new esri.symbol.PictureMarkerSymbol("btb.png", 16, 16); var graphic = new esri.Graphic(point, symbol); var layer = new esri.layers.GraphicsLayer(); layer.add(graphic); map.addLayer(layer); dojo.connect(layer, "onClick", onClick); function onClick(evt) { map.infoWindow.setTitle("Test"); map.infoWindow.setContent( "test test test test" ); map.infoWindow.show(evt.screenPoint); } }); }); </script> </head> <body class="claro"> <div id="mapDiv"></div> </body> </html>
