I have created a dashboard which looks at data that has been published to my SDE. The SDE feature service contains 2 polygon layers and 1 point layer. My 2 polygon layers are being drawn out but are filtered down with the initial startup of the dashboard. My point layer is considered "big data" of which I have turned off visibility and am primarily only interested in the attribute information. The dashboard contains a number of widgets which filter out the attribute information from the point layer and some information from the polygon layer.
My problem is, when I load the dashboard for the first time, only a handful of the widgets will load with the desired information while the remaining widgets will keep spinning and eventually returns a "cannot access data error". If I go to refresh the page, it appears the service times out as no data will load and at times the widgets state they have not been configured. When I do get all the widgets and data to load, I am able to filter and run through the widgets without issue.
Is there some publishing settings or server setting I should be looking at to improve my initial startup? Or increase the performance of large datasets overall?
