Steps to reproduce:
- Load a world map with the following spatial reference:
| PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0]] |
- Enable wrap-around at the 180 degree meridian
Center the map on the 180 degree meridian at the equator (near baker island), configuring the map extent so the bottom left and top right corner are as follows:
bottomLeft: Point [m_attributes=[1.9449581424337383E7, -626899.6119120895], m_description=com.esri.core.geometry.VertexDescription@7c5d0f85] topRight: Point [m_attributes=[2.0623654149388406E7, 706162.1279895945], m_description=com.esri.core.geometry.VertexDescription@7c5d0f85] |
- Attempt to extract and convert these points to WGS84, using:
Point bottomLeft = mMapView.toMapPoint(0, mMapView.getHeight());
Point topRight = mMapView.toMapPoint(mMapView.getWidth(), 0);
SpatialReference WGS84 = SpatialReference.create(SpatialReference.WKID_WGS84);
Point wgs84BottomLeft = (Point)GeometryEngine.project(bottomLeft, mMap.getSpatialReference(), WGS84);
Point wgs84TopRight = (Point)GeometryEngine.project(topRight, mMap.getSpatialReference(), WGS84);
Expected result: Two valid WGS84 points
Actual result:
wgs84bottomLeft: Point [m_attributes=[174.71856263209403, -5.622489445477077], m_description=com.esri.core.geometry.VertexDescription@7c5d0f85] wgs84topRight: Point [m_attributes=[NaN, NaN], m_description=com.esri.core.geometry.VertexDescription@7c5d0f85] |
This issue becomes even worse if you move the extent further east, and you can easily get into a situation where both points return NaN.
