I am trying to create a custom subclass inherited from the WebTileLayer class using esri/core/Accessor. I was following the doc from here: Accessor | API Reference | ArcGIS API for JavaScript 4.3
My custom class module is the following:
<SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/layers/WebTileLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/support/TileInfo"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>WebTileLayer<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN> TileInfo<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> WebTileLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createSubclass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
constructor<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>urlTemplate<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>urlTemplate <SPAN class="operator token">=</SPAN> urlTemplate<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>spatialReference <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3857</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>initialExtent <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>fullExtent <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">20037508.34787</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">20037508.34278</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">20037508.34278</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">20037508.34787</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>tileInfo <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TileInfo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"size"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">256</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dpi"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">96</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"format"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"PNG"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"compressionQuality"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"origin"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"x"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">20037508.342787</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"y"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">20037508.342787</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3857</SPAN>
<SPAN class="string token">"lods"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">156543.033928</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">591657527.591555</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">78271.5169639999</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">295828763.795777</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">39135.7584820001</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">147914381.897889</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">19567.8792409999</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">73957190.948944</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">9783.93962049996</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">36978595.474472</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4891.96981024998</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">18489297.737236</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2445.98490512499</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">9244648.868618</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">7</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1222.99245256249</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4622324.434309</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">611.49622628138</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2311162.217155</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">9</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">305.748113140558</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1155581.108577</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">152.874056570411</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">577790.554289</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">11</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">76.4370282850732</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">288895.277144</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">12</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">38.2185141425366</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">144447.638572</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">13</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">19.1092570712683</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">72223.819286</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">14</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">9.55462853563415</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">36111.909643</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">15</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4.77731426794937</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">18055.954822</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2.38865713397468</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">9027.977411</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">17</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1.19432856685505</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4513.988705</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">18</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.597164283559817</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2256.994353</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">{</SPAN> <SPAN class="string token">"level"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">19</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"resolution"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.298582141647617</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"scale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1128.497176</SPAN> <SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
getTileUrl<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>level<SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> maxY <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getTileMaxCountY</SPAN><SPAN class="punctuation token">(</SPAN>level<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> updatedRow <SPAN class="operator token">=</SPAN> maxY <SPAN class="operator token">-</SPAN> row <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>urlTemplate<SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{level}"</SPAN><SPAN class="punctuation token">,</SPAN> level<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{col}"</SPAN><SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{row}"</SPAN><SPAN class="punctuation token">,</SPAN> updatedRow<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
getTileMaxCountY<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>level<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN>level<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">32</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">6</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">64</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">7</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">128</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">256</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">9</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">512</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">1024</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">11</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">2048</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">12</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">4096</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">13</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">8192</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">14</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">16384</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">15</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">32768</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">65536</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">17</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">131072</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">18</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">262144</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">19</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">524288</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">20</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">1048576</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">case</SPAN> <SPAN class="number token">21</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">2097153</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">default</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>When I initialize a new instance of this class doing: new MySubClass("https://mydomain.com/msp/{level}/{col}/{row}.png");
I got the errror this.load() is not a function. this.load() is called at the end of the constructor method of my subclass, and this method should have been inherited from WebTileLayer class. Why this method is not accessible from the subclass?
Thank you,
Maxime
