hi: just one GeoEvent is too simple, i want to make a GeoEvent clusters. in the com.esri.ges.messaging.jms.cfg i see some things.
com.esri.ges.messaging.jms.destinationPolicy.queue.memoryLimit=100 mb
com.esri.ges.messaging.jms.destinationPolicy.topic.memoryLimit=100 mb
com.esri.ges.messaging.jms.systemUsage.memoryUsage.limit=128 mb
com.esri.ges.messaging.jms.systemUsage.storeUsage.limit=100 gb
com.esri.ges.messaging.jms.systemUsage.tempUsage.limit=10 gb
com.esri.ges.messaging.jms.brokerNamed=192.168.110.111
com.esri.ges.messaging.jms.dataDirectory=\\chenjun\data\activemq\localhost
com.esri.ges.messaging.jms.kahadbDirectory=\\chenjun\data\activemq\localhost\kahadb
com.esri.ges.messaging.jms.openwire.uri=tcp://localhost:61616
com.esri.ges.messaging.jms.stomp.uri=stomp://localhost:61613
brokerNamed is the master node?dataDirectory is the ActiveMQ Directory?kahadbDirectory is the kahadb Directory?i see some paper about the ActiveMQ,maybe the GeoEvent Architecture is Msater-Slave+Broker Cluster mode. is the geoEvent now support Cluster? if so, how can i modify the com.esri.ges.messaging.jms.cfg file??i try to modify the file like this:in master i do nothing,but i shared a folder(C:\Program Files\ArcGIS\Server\GeoEventProcessor\data)in slave i modify the com.esri.ges.messaging.jms.cfg file
then, i send many messages to the master node. all messages is being Processed by the master machine, no messages is being blanced to the slave machine. i want this:when messages is too much, master and slave machine can process it together. one message only being processed once. like the arcgis web adaptor .so,how to do?thanks
