When I try to run arcpy.MakeQueryLayer_management from the python command window, I can't get the resulting table added to the ArcMap display.For example (I've changed the details to a generic case):>>> arcpy.MakeQueryLayer_management('Database Connections\my_database.sde','a_table_view','select a_field from some_table','a_field')The database I'm querying is Oracle 11g.The command runs successfully (python returns <Result 'a_table_view'>, but when I go to the arctoolbox results tab, rt-click on the output, and choose Add to display I don't get anything. Likewise I can't seem to find this table through the various listing methods:>>> mxd = arcpy.mapping.MapDocument("CURRENT") >>> df = mxd.activeDataFrame >>> arcpy.mapping.ListLayers(mxd,data_frame=df) [] >>> arcpy.mapping.ListTableViews(mxd,data_frame=df) [] >>> I've also tried getting a reference from:arcpy.mapping.TableView('a_table_view')and get an Assertion error.Any ideas?Thanks,Tim
