I'm looking to edit some XML's to upload into some feature classes as metadata. I'm having a little trouble trying to edit/add tags to update the Time Period tab in the ArcCatalogue metadata editor (9.3) using python and the elementtree module. In this tab, there are 3 options for date. Single date, multiple dates and a range of dates. I want to set a parameter so the user can choose between these 3 options and add dates. I have the range of dates figured out, but the multiple dates I am having trouble with. I'm thinking I need to find and replace the tags I want, but I'm not sure how to accomplish this. I've tried a number of codes I found, but nothing seems to work. My code goes a little like this:
folderPath = "Z:\ESRI\Figure_Sourcing\Figures\Metadata\IOR_Run_Metadata_2009"
for filename in glob.glob(os.path.join(folderPath, "*.xml")):
fullpath = os.path.join(folderPath, filename)
if os.path.isfile(fullpath):
basename, filename2 = os.path.split(fullpath)
root = ElementTree(file=r"Z:\ESRI\Figure_Sourcing\Figures\Metadata\IOR_Run_Metadata_2009\\" + filename2)
iter = root.getiterator()
#Iterate
for element in iter:
print element.tag
if element.tag == "begdate":
element.tag.replace("begdate", "sngdate")
My XML looks like this. I want to replace the rngdate, begdate and enddate tags so that it looks like the XML at the bottom of this post.[HTML]<metadata> <idinfo> <citation> <citeinfo> <origin>My Company Name</origin> <pubdate>05/04/2009</pubdate> <title>Feature Class Name</title> <edition>0</edition> <geoform>vector digital data</geoform> <onlink>.</onlink> </citeinfo> </citation> <descript> <abstract>This dataset represents the GPS location of inspection points collected in the field for the Site Name</abstract> <purpose>This dataset was created to accompany the clients Assessment Plan. This point feature class represents the location within the area that the field crews collected related data.</purpose> </descript> <timeperd> <timeinfo> <rngdates> <begdate>7/13/2010</begdate> <begtime>unknown</begtime> <enddate>7/15/2010</enddate> <endtime>unknown</endtime> </rngdates> </timeinfo> <current>ground condition</current> </timeperd>[/HTML][HTML]<metadata> <idinfo> <citation> <citeinfo> <origin>My Company Name</origin> <pubdate>05/04/2009</pubdate> <title>Feature Class Name</title> <edition>0</edition> <geoform>vector digital data</geoform> <onlink>.</onlink> </citeinfo> </citation> <descript> <abstract>This dataset represents the GPS location of inspection points collected in the field for the Site Name</abstract> <purpose>This dataset was created to accompany the clients Assessment Plan. This point feature class represents the location within the area that the field crews collected related data.</purpose> </descript> <timeperd> <timeinfo> <mdattim> <sngdate> <caldate>08-24-2009</caldate> <time>unknown</time> </sngdate> <sngdate> <caldate>08-26-2009</caldate> </sngdate> <sngdate> <caldate>08-26-2009</caldate> </sngdate> <sngdate> <caldate>07-07-2010</caldate> </sngdate> </mdattim> </timeinfo> <current>ground condition</current> </timeperd>[/HTML]
