This -
esri.renderer.UniqueValueRenderer(defaultSymbol, attributeField, attributeField2?, attributeField3?, fieldDelimeter?)
Creates a new UniqueValueRenderer object. Typically features are rendered based on the unique values of one attribute field. However up to three fields can be combined to generate a unique value. For example, if two fields are used which store the values A and B; and X, Y, and Z respectively, then the unique values for the renderer can be A:X, A:Y, A:Z, B:X, B:Y and B:Z, assuming ":" is the field delimiter.
would lead me to believe that this -
var salesRepsRend = new esri.renderer.UniqueValueRenderer (new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CROSS, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,0,0.25])),"PCText", "Ldr_type", "Name" ":");
salesRepsRend.addValue("0:0", new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,255,0.25])));
salesRepsRend.addValue("1:0", new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_X, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,255,0.25])));
salesRepsRend.addValue("0:1", new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 1), new dojo.Color([0,255,255,0.25])));
should work. which is not the case. I'm really only interested in rendering based on 2 fields, PCText and Ldr_type, but I get "esri.layers.FeatureLayer: unable to find ':' field in the layer 'fields' information [url: " if i don't fill in the third attribute.so my problem is that it doesnt render uniquely, everything renders with the default renderer. Any ideas?Thanks,Evan
