Hello everyone, I would like to display popup info windows into two tabs. Could someone point to some links where I can refer to? I have tried jquery UI, here is how I built the info windows
var div = "<div>";
var table = "<table border='1' width=300>";
for (prop in graphic.attributes) {
table += "<tr><td>" + prop + "</td><td><b>" + graphic.attributes[prop] + "</b></td></tr>";
table += "</table>";
I tried to build it this way, and it didn't work:
var div = "<div id='tabs'> <ul><li><a href='#fragment-1'><span>Layers</span></a></li><li><a href='#fragment-2'><span>Query</span></a></li></ul>";
var table = " <div id='#fragment-1'><table border='1' width=300>";
table += "</table></div><div id='#fragment-2'>test</div></div>";
Here is my jquery code:
<script>
$("#tabs").tabs({ active: 1 });
</script>
Thanks.
